Executes the specified Universal Port profile on the switch.
| profile-name | Specifies the UPM profile to be run. |
| event-name | Specifies an event type for the specified profile. Valid event types are device-detect, device-undetect, user-authenticate, and user-unauthenticated. |
| variable-string | Specifies a string of variable names and the assigned variable values to be used in the profile. The format is: var_name1=value_1; var_name2=value_2; var_name3=value_3. Each variable name is followed by the equal sign (=), the variable value, and a semicolon (;). |
N/A.
The following command runs a UPM profile called example on the switch:
run upm profile example
This command was first available in ExtremeXOS 11.6.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the Universal Port feature, see the Switch Engine v33.1.1 Licensing Guide document.
